Has anyone experienced two toilet drainage issues where waste water does not go from the toilet bowel plumbing to the holding tank? If yes, how did you correct the problem?
I bought a rebuild kit for my head to fix this problem. The kit contains seals, gaskets, and a new joker valve.
If you haven't rebuilt in more than a couple years, this is likely your problem. The joker valve has a finite service life.
