The other week right after we put my friends Colgate 26 in the water ( he was away on business) I attempted to start his outboard so I could take the boat to his mooring.
I almost ripped my fingers off as the motor was locked up HARD. After some troubleshooting we removed the starter cord mechanism. That worked OK. Then I tried turning the crankshaft by hand -- no luck. Then I turned it backwards and that worked. Then forward and it worked.
Re-installed the starter cord mechanism and the motor started -- but very smokey.
Turns out if you store the motor on it's side, crankcase oil will fill the combustion chamber, and as many of you might be aware -- liquid is not compressible. The owners manual says if you store the motor on it's side, to store it on the handle side. The search I did on the internet, a person says, doesn't matter what side, it will eventually leak oil into the combustion chamber.
http://www.pensacolafishingforum.com/f2 ... art-93408/
An easy fix would be to remove the spark plug and blow the oil out. This problem might show up on other 4 stroke engines.
Moral of the story ---- store your four stroke in the vertical position to be safe
Hershey
Hershey
