Tohatsu 9.8 Electric start battery
Nov 19, 2009
289
Hunter 45CC Ft Pierce and Abaco Bahamas
So I bought a new Tohatsu 9.8 4 stroke with electric start and it does not come with the battery. The suggested battery from the owners manual is:
12V 40Ah/5Hr 350 CCA. I went to a local auto store to ask about their motorcycle batteries and I gave them the number of the recommended battery and they looked at me like I had a 3rd eye. They had never heard of the 40Ah description. So the guy looked on the internet and according to him it suggest "This battery" (pointing to it. It was nearly the size of one of my house batteries. I said sorry, no way and I putting that in my dink. So my question to you all that have electric start outboards, what battery do you use?
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Walmart has lots of lawn tractor batteries and you should find one that will work fine. I use a tractor battery in my dinghy. Chief
Likes: RWSlater
Nov 19, 2009
289
Are they generally smaller that a motorcycle battery?
Gunni
Mar 16, 2010
5,937
They assume that you will use the battery to power accessories on your boat. If all you are trying to do is start a 10hp dink outboard you can do that with an 18Ah generator battery. This is a wet application, suggest you go with sealed battery (AGM or Gel)
Likes: RWSlater
Nov 26, 2012
2,315
Usually bigger than a m/c battery but Gunni is telling you that it does not take much of a battery if all you use it for is to start the motor. Walmart has some for $20. I use my lawn tractor battery to run a small electric trolling motor as well. Chief
Likes: RWSlater
Nov 19, 2009
289
Yep it's just to start and then the motor charges it
Joe
Jun 1, 2004
8,261
Maybe a personal watercraft / motorcycle / atv dealer would be more helpful.
Likes: RWSlater
Nov 19, 2009
289
Yep. This store was convenient right across from the barber. I'll check sears out and Walmart.
Nov 26, 2012
2,315
RW: Beware of buying in ATV, motorcycle shops as they tend to charge more. I know, I am an ex Yamaha dealer. Chief
