Tim
The port toerail on my 1985 model H31 was damaged during on of our hurricanes last fall. Working with the insurance folks and boat yard to come up with a reasonable replacement (can't be repaired). So far all Hunter has been able to provide is a replacement rail which will have to be custom fit (with some fairly major alterations to the hull/deck joint) from a newer model of the boat. Does anyone out there know where/if there is an "aftermarket" supplier of our toerails? It is critical that the replacement toerail fit a 1984-86 Hunter 31 since later boats had a slightly different toerail. Thanks!Tim L.
