Jim
Hello,Thank you for the suggestions for adhevisive or caulk for the toe rail reinstall.As I removed the toe rails I found that the substance is not a caulk but a layer of adhesive of some kind. I t looks like it was installed in a band of about one inch wide and then the rail set in place and screwed down. Anyone know what this stuff is and where it can be found. i have not had a chance to contact Hunter yet. Any suggestions for a substitiute? I was thinking in the direction of automotive trim adhesive strips. Whatever is used it cannot harden, it must remain flexible. The rail moves and twists (not that much, but it does) with the deck and hull.Any help would be appreciated.Jim
