my 81 c&c34 seems to leak at the hull to deck joints. has anyone ever removed the toe rail to rebed it? any better ideas?
C&C sealed most of their hull to deck joints with butyl tape during the assembly process. If you look inside the cabin at the joint you will see a pliable grey material being squeezed out of the joint. Over the years there may have been a leak which a previous owner handled incorrectly.
To fix a leak correctly on a C&C, all you should do is slightly snug up on the bolts in the area of the leak just enough to stop the leak and nothing more. If the bolt is tightened too much it will squeeze out all of the butyl tape and it will continue to leak. It is very important that you have a helper when tightening the bolts. One person on the outside must hold the bolt securely to prevent it from twisting. The other person inside the cabin will tighten the nut slightly. The bolt must not be allowed to turn or the seal will be broken and a leak may occur at the bolt. If it looks like too much butyl tape has been forced out of the joint you can try loosening the bolt and forcing some butyl tape back into the joint from inside the boat.
