toe rail for 1984 hunter 37 cutter
15
2 -37 cutter Hamilton, Ontario
hoping someone may be able to direct me to a supplier of toe rail for my 1984 hunter cutter 37. The bow was damaged when we bought her and there was about 4 feet on each side of the hull that was missing and had been replaced with an angle aluminium that was just glued on. thanks for your help Don
Jun 2, 2004
5,802
Maybe Rig-Rite?
Check Rig-Rite in the Related Link below. The problem is that the aluminum has oxidized and changed color. Yours is probably like mine, black. I wish that I had the cash to replace it all. Then I would have to do a job that has always needed done, seal all the toerail bolts and stanchion bolts.
Dec 3, 2003
2,101
Try HMP!
They are in Canada and have an oline store that sells toe rails. See the link: http://www.hollandmarine.com P.S. I have seen toe rails in the past on that site!
