Andy,
I would ask your dealer why you need to loosen the shrouds to reduce the tension loading. First, the side loading due to wind will remain the same no matter the shroud tension. If the wind exerts 200#'s of force on the rig, it makes no difference. Further more, a loose rig will increase wear and decrease stability.Second, as the tempature drops during the winter, the aluminum mast will shrink its length far more than the steel shrouds which will automatically reduce rig loading to the hull during layup without making the rig loose.I'm affraid that I would have to question all that this dealer is offering as advice.
