To shrink wrap, or not?
Dunham
Jun 21, 2012
33
Hunter 33 Island Yacht Club
Hello everyone,
It's almost that time to start thinking of winterizing our sailboats in Ontario. Do most people shrink wrap their boats? I've heard now adays because of the fibreglass, it's ok to not shrink wrap a boat. But, I can't imagine leaving a sailboat out in the cold for months.
Thoughts?
Apr 27, 2010
968
Beneteau 352 Hull #276 Ontario
I build a frame from conduit and Kwik-Klamps, then cover with a tarp. I also un-step the mast.
It's not the winter that causes the problems, it's the thaw and freeze cycles that we have.
I don't even want to think about it yet:naughty:
7,337
Alden 50 Sarasota, Florida
I'd love to hear what someone gave you as an explanation why today's fiberglass is different than it was previously.
Regardless, if water gets into cracks, pores or joints, it will cause damage due to freezing. Boats have cracks, pores and joints. Fiberglass boats have more than steel or aluminum boats. If you want to protect your boat, cover it and shrinkwrap, although not the "greenist" method, protects best as long as you allow for some ventilation.
Oct 25, 2011
576
Island Packet IP31 Lake St. Louis, Montreal
Crappy Tire tarp
From my perspective, with my boat over wintering in Montreal I do not shrink wrap it. I go to Crappy Tire and buy a tarp that is large enough for the whole boat and cover the boat with that. it keeps the snow and ice off just as well as shring wrap, is less expensive and is reusable for multiple winters. ( ............and there is no kid with a blow torch anywhere near my boat. :D) This has worked well for the last 20 years+
Which ever you decide to go, do visit the boat regularly during the winter to make sure things are ok, especially after a snow storm.
Cheers
Matt
Sep 20, 2006
2,952
Yes you should cover it somehow over the winter. We get too many freeze / thaw cycles that gets water into everywhere then freezes and will do damage.
Shrink wrap is the most expensive if you have the marina do the work, but easiest. You don't have to do the work, but current rates are around $20 per ft, so makes it $ 600- 700 per year. You can do shrink wrap yourself, but equipment is more expensive and takes some technique to get it right. Get it wrong and it will cost you even more. But, lots of people do it themselves, all depends on your capabilities and available time. Tarping / wrapping will take at least one weekend the first time, then down to one day once you know what you're doing.
Custom tarps will run $2-3,000 depending on if you need frame etc. Check Genco for one, I think they have templates for most boats.
Econo tarp is from TSC ( not sure if you have one near you ) I used a hay bale tarp, heavy silver ones from TSC and has lasted 4 seasons, $ 200. I made a ridge frame from 2x4's and made the tarp steep and and very tight so the snow does not accumilate. Has worked without any problems. Tarp is on its last legs so will be time for a new one. For comparison, custom tarps should give you 10 yrs. or more.
As far as timing..... I'm usually still in the water over Thanksgiving and then winterize / tarp late Oct. / early Nov. Season is too short as it is....
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
You have a nice new boat, I would buy a cover for it.
At least a cheap tarp that will last for a few years or you can order a custom fit one from the Top Shop (http://www.topshop.on.ca/boat-list.html) in Kingston. They seem to be the favourite in eastern Ontario. Very good quality and nice to deal with.
I ordered just a tarp from the Top Shop, with a "V" cut out of the front portion to match the bow of our boat. It was a 26 ft boat so ordered a 35 ft tarp. It came with nice loops of webbing along the edges and brass grommets at the bow end. I used the mast as a ridge pole and stored the boat like this for several winters. It was a much cheaper alternative to a custom tarp and frame. The snow would usually just slide off. The fabric can breath so much better for the boat, keeps the UV off of it too.
good luck, Bob
(I'm just a very satisfied customer, no connection to this business)
Hunter 29.5 Gloucester, VA
I have a full canvas cover for mine. Winters here aren't usually that harsh. I does keep her cleaner and the UV off the deck. Several checks during the winter it was quite comfortable down inside. There is also the lack of scrubbing off bird droppings.
958
Hunter 260 Pepin, WI
I've been storing my boat outside in the harsh Minnesota winters since it was new in 1996. I have never shrink wrapped it. I also use a high quality canvas tarp to keep the snow off the deck and out of the cockpit.
Since mine is a trailer boat, it is stored with the mast down. That makes it easy to create a tent. I just need to put a crutch in the center to keep the snow load from bending the mast.
