To; Peggy - Head Mistress
Bob F
Thank you for your response to my post about holding tank chemicals. In order to switch over to KO or odorlos do I need to do anything special, or just empty and flush out (with water) and start using the KO? I see "shock" treatments in WM and I wonder if they're needed. BTW, I'm going to get your book too to keep on-board for when (and if) a problem comes up (or wont go down!). Thanks, Bob
Peggie Hall/HeadMistress
Just flush VERY thoroughly with plenty of
clean water. Best way is to put a few gallons down the pumpout--'cuz that sends water in at the bottom of the tank to stir up any sludge--pump out...repeat...till what you're pumping out is clear. Also flush out the vent line and vent through hull.
Terry
Hi Bob, I'm thinking about getting her book, too..
It might make a good coaster...he he. Oh, hi Peggie, any plans to visit the NW for a book signing get-together with your fans? Terry
Unlikely I'll make it to Seattle...
My publisher only sends authors to the major national/regional shows. PSE is the only one on the west coast. However, if the PNW crowd put together a Rendevous of the sort the Chesapeake Bay "mafia" holds every two years, I could be persuaded to come.
