Tire/Whell size for Hunter 26SL trailer
5
Hunter 23.5 Sebastian, FL
Does someone know the tire/wheel size that came on the Hunter trailer for a 1994 H26SL? 5 or 4 hole pattern?
Thanks!
Chris
May 27, 2012
1,152
Oday 222 Beaver Lake, Arkansas
Hunter didnt build the trailer, and likely didnt even spec it. Most often the dealer/buyer makes that choice. Also, an owner may upgrade the trailer.
What is on the trailer now? If your unsure, drive the trailer over to a boat/trailer/tire center, one of them should be able to figure out what you need.
Alternatively, Walmart, Tractor Supply, etc., also have mounted tires and wheels for trailers. You should be able to find one of them that would work.
-na -NA Anywhere USA
Hunter did indeed build the trailers for the 23.5, 19 and 26. That ended when they went to the 240 and 260 from Magic Tilt. It is a five lug pattern. It is either a R15 or R14. If you look at what is on the 23.5 trailer, same size but with a second axle on the H26 trailer. If you are near any of the Hunter water ballast trailers for the 240, 26 or 260, simply look on the sidewall and you will see the tire size. Sorry I cannot be more specific as it has been some time since I was around that trailer.
crazy dave condon
anchorclanker;
I did alot for this industry and only if you knew. However, I just share my knowledge in the hopes it helps folks here only.
crazy dave condon
BrianW
Jan 7, 2005
843
Hunter 26 Guntersville Lake, (AL)
My H26 trailer has 5-bolt wheels, Carlisle U.S.A. Trail ST205/T5D14 load rating C (LRC) tires. BrianW
