Tipping a Javelin
C
Capitania
We just aquired a '71 Javelin (14) that we love. It sails like a dream but we wonder how easy or difficult it would be to tip over. Also ... How hard it is to right them? Can 2 people do this fairly easily or do we need the coast guard? Does anyone have any stories on this subject?
Josh
Should be easy...
I'm not certain, but if I'm right the Javelin is a small dingy. If so, righting it should be a fairly easy process. I was unable to find anything specific as to how to do it on the net, but maybe someone else can. Check second hand book stores for books on sailing if you want to purchase something cheap. Otherwise go to the local chain, check out the 'Sailing for Dummies" book, and it will show you step by step with pictures what you'd need to do. Doesnt appear to be a difficult process. Never had to worry about it, and hopefully wont with a weighted keel on my 22! Josh
Mike Whalen
I've never sailed a Javelin but do have a dingy that is 2 feet shorter with about the same beam measurement. It's damned hard to turn over. In fact I never have and I've sailed it in pretty heavy wind. I control the main sheet by hand and find that long before it gets to the point of going over, I've let go, the wind is dumped and its luffing like hell but dry side up. I have tipped my AquaFinn and find that the sail stops it from going upside down quickly. With that one you just stand on the centerboard, reach over the rail and lean back. It looks like your boat has a lot of sealed floation so it shouldn't be that hard to right it. Later, Mike
Justin - O'day Owners' Web
You should probably try it -
The Javelin is a good little boat but like any dinghy it can be capsized. Righting is not tough, however. You simply stand on the ceterboard until the boat starts to come up and clamor over the rail. Make sure the main sheet is not cleated or water will pile up on the sail and make it tough. I'd try it though - its not difficult but being in the water can be unnerving if you don'e know what to do. Justin - O'day Owners' Web
Patrick Kaur
Should Try It
Everything I have read recommends that you tip your boat at least once for practice. Your should do this when you have control and the conditions are good. That way when it does happen under adverse conditions you will know what to do.
