Mark
I really love the look of navy blue and green above the waterline hulls. So, I decided to paint my Cherub. 25 1976 a Navy Blue, I had painted my 16' catarmaran in the past but that was several years ago and it was fiberglass on wood not gelcoat. I did alot of research and asked both West Marine and Brewers how to go about painting a gelcoat boat with minimal damage (scratches and dings). One suggested spraying then wet sanding (that now makes sense) the other suggested "Tip and Roll with a thick China bristle brush and a foam roller. I chose the easier root since I have a busy schedule and limited time. I prepared the hull with Marine-Tex and Gelcoat repair. Then I began my painting on a dry sunny day with limited wind. I used Interlux Brightside. The trouble with boat paint is that it is basically glue with color in it! It starts to dry in approx. 15 seconds but will run for ten minutes. I rolled the paint vertically and brushed it out horizontally. Much to my horror, the paint started to run so I brushed it out again, and it ran again. So I went back and brushed it out again although at this point it was starting to dry and the run became permanent. At this point it was a time issue, I couldn't very well stop as stoping would create one big dry spot (holiday in painter;s terms) with a different texture to it so I labored onward. I tried every variation, I used a different roller pan that wrung out the roller better, didn't work. I kept the brush out brush dryer so that there wasn't too much paint on the hull, that didn't work, it still ran. What am I doing wrong? What should I do now. It looks great from a distance of 15 feet but up close it look terrible. Should I go back and sand the first coat down with fine sand paper then paint it again or should I just leave it alone and make sure I never come into port. Suggestions appreciated.
