tiller to wheel steering conversion
G
Gary Cyr
I would like to convert to wheel steering on my 1978 hunter 27'. please forward any info regarding this. The 27 has a weather helm and i have broken 2 tillers.
Mike Cummings
Wheel
I had a hunter 27, 1978 that i converted to wheel stering. (1) I used BoatUS to purchase all the edison parts. (Dont buy direct, they will not discount a lot). (2) Call Edison tell them your interested in a conversion and they will send you diagrams with all the part numbers and a catalog. (4) hard part is cutting the enclosed rudder post to attach the quadrant. Email me at mpcsail@aol.com for specific questions or anything else. It took two of us a weekend to install everything. Remember MEASURE TWICE CUT ONCE!!!!
N
Neil Smith
Whitlock
There's a really good system out there through Whitlock, it's rack & pinion. The system is called the Cobra. The beauty of it is that it eliminates the play that you will find with the conventional cable & chain arrangement with Edson, and as an added benefit, it's much less expensive. The unit will come with compass, rail, brake and wheel for under $2k. If you don't need the compass or rail, obviously it's even more economical.Go to www.pyi@pyiinc.com and check out the Whitlock page. Good Luck! Neil Smith
Aug 11, 2006
1,446
Hunter H260 Traverse City
Whhel steering
Also available from Edson. Saw in the new West Marine catalog.
