tiller side load at > 5 knots
Jun 1, 2005
16
Hello,
I have recently bought vega 1010 which is in Cyprus. I am experiencing
a significant side load on the tiller when sailing at more than 5 knots
with full sail, the boat wants to turn into wind. The rigging seems ok
and the mast is vertical. I have inspected the hull when she was out of
the water recently and all is ok
Can anyone tell me why this is?
Regards: Patrick
Oct 31, 2019
562
Hello Patrick;
you're lucky: That's what a sailboat is supposed to do-
turn into the wind when you let go the tiller! It's called
the "weather helm". Though you can change the force by
changing the mast's rake; the more forward the weather helm
is less, if you rake the mast back, the weather helm will
increase. You should never have a negative weather helm,
meaning the boat will fall off the wind.
Wilhelm, V-257
Nov 8, 2001
1,818
Hi Patrick
Sounds like you have too much sail up! Try reefing the main in anything over
15 - 18 knots as this will make a lot of difference. The Vega likes to be
reefed sooner than later.
Cheers
Steve Birch
