A
Arturo DeVitalis
After seeing the post about a $100 fabricated tiller holder thought I would give this a try, and will let you know how it works.1 1/4" PVC end cap fitted over the table post with a hole drilled in the cap to accept an oar lock. (Of course you remove the table first!) The 1 1/4" cap ID fits perfectly and the oar lock has a cotter pin hole on its stem whick keeps it connected to the cap. More later.
