Hi All,I have finally got around to addressing my loose tiller and had concluded that the pin needed to be replaced because I'm sure its original to the boat (Vega # 2548). I took the tiller off and and gently tapped the pin going starboard to port. After the second tap or so a 1/2" piece of the pin popped out of the starboard side. Having never dealt with this issue on any boat I have owned I am suspecting that the pin is broken hence the wobble to the tiller. Am i correct in thinking this? I will be back at the boat this weekend with proper tools to knock the rest out if that is how I am to proceed. Am I proceeding the right way? Is the pin tapered so it is one directional? Will I have to drill it out (or the burred end at least)? Is there a vega replacement part for this or is this a machine shop project? Thanks group!!BradBiddeford Maine U.S.A.Vega 2548
