Hello,I know this was recently discussed but I can't seem to find the posts in the archives (archives may still be down) and was hoping to work on my problem tonite or tomorrow.The adjustment screw located on the most aft end of the tiller on my H240 apparently has become stripped as it is pushed in all the way and now the tiller moves (falls) to far downward and rubs on the King Starboard (as well as my engine remote control handle) and there seems to be a lot of looseness in the control of the tiller and rudder shaft (rudder post). Not sure how the adjustment screw got pushed inward on the tiller, but it did. It must be stripped.Question then: what does anyone suggest for correcting this problem. I assume I will have to take the tiller off of the rudder post because as it sits now, I can't reach the adjustment screw. Then, I am thinking that I will have to get a larger screw and use it in place of the current one OR do I have to re-tap the hole as well?? What size screw has anyone else used for this problem.Also, when this happened to you, did you experience a lot of play in the tiller-rudder system??Really appreciate anyones suggestions on this. Thank you and good sailing.Daniel
