Josh
Does anybody know what the optimal tool/combination of tools is/are to tighten the toe rail screws. Ed, I remember that you recommended a vice-grips on the nut below, a large screw driver above and a vice grips on the screw driver, so that you turn the vice-grips on the screwdriver, while leaning on the screw driver from the deck. Is that correct? Has anyone had any luck doing anything else? I'm going to try to tighten a few that leak and probably all of them, if I don't go nuts in the process. Any tips on this project would be greatly appreciated. Saving a couple minutes on each nut could add up to hours when you factor in how many there are.
