N
Nelson Brinckerhoff
I race my 1996 H26. It has roller furling. To get the forstay tight enuf I have to crank up the turnbuckles for the upper and lower shrouds on both sides, which of course are in lieu of a backstay. This causes an upswelling at the rubrail attachment point which is a little disconcerting but seems to be okay as there is a metal plate underneath and both the deck and hull sections are also joined there. I tried to loosen the pull there but found I then got too much sway in the forestay in heavy wind so I re-tightened half of what I let off.Any thoughts?
