tightening keel bolts question
W
william
i was told by the previous owner that hunter recommended tightening the keel bolts every 5 yr. is this covered in the owners manual? (i have one coming from hunter). will i need to reseal the bolts and recaulk too? if so what is the best sealent and caulk to use.
Jim
keel bolts
check tightness of keel bolts every year. coat them with wheel bearing grease. I assume the bolts are stainless to less noble metal. Grease should be applied when bolts are bone dry. Use a heat gun {carefully} or hair drier in a dry bilge. Regards, Jim
