Tightening engine mounts on 79 Hunter 30
Bob Alden
Hello,
I have a loose engine mount on the forward, port side of a 1979 hunter 30 with a YSM 12. I cannot find away to access the bolt from under the fiberglass rails the engine mount attach es to. Is there an access point or a way to get under the mounts into the fiberglass rail to hold the hardware to allow tightening?
Thanks,
Bob Alden
Feb 17, 2004
268
Hunter 30_74-83 Lower Salford, PA / Tolchester,MD marina
Just checked my 1979 Hunter 30' with YSM12 engine. I have holes drilled in the side of the rail so you can fit an open-ended wrench into the hole to hold the bolt head, so you can tighten the nut. Each mounting backet has two holes drilled beneath it for this purpose.
Hope this helps.
Ian
s/v Meant to Be
