Why?
Nick,I am not aware of any issue on that yeae Catalina with the thru hull valves,unless they are not functioning properly, which would neceissitate replacing. It is prudent that you check the clamps attaching the hoses to the valves and make shure they and the hose clamps (double clamped) are in good shape. It is my opinion that all thru hulls should be closed when leaving the boat for extended periods of time. This keeps the valves operational and should keep the boat floating should the connecting hose fail.Tom Behrendt
