thru hulls
Phil P.
I am considering installing two thru hulls in the port side transom near the motor mount. One for the fuel line and battery wires and one for the soon to be purchased bilge pump. The fuel and bat.lines now are stuffed thru the vent scoop. I think it might look better to run them thru the thru hulls. I saw some pictures with this set up and it looked good. I also saw some that ran the bilge pump hose high thru the side of the hull. I thought I would have less chance of water comming in thru the transom set up. Please give me your opinions Thanks! Phil
Joe
Jun 1, 2004
8,342
Put a loop in it....
...here's an article from that most excellent website - Yachtsurvey.com - with a diagram of the pump out system. http://www.yachtsurvey.com/bilge_pumps.htm
