Don
I've read some interesting comments in the archives on this subject but I have a few more questions.1. What is the proper bedding compound to use for the thru-hull fittings?2. Whats the reason for sea-cocks verse's ball valves. I realize "I believe" that on the seacocks they have a locking and unlocking mechanisium, is there a reason or purpose for that?3. What the best way to go 'bronze' or 'plastic' thru-hulls? And what about using plastic female ball valves for shut-offs? I'm planning to pull my 27h out of the water soon to replace or fix the transducer to my knotmeter 'as previously mention in an earlier topic'. Well at the same time I plan to replace all my thru-hull fittings and my sea-cocks. I will also be replacing my 'Y' fitting for my toilet 'as it is broken'. At 65.00 hr to have a mechanic help me, I was hoping to do most the work myself. What has me worried is its not like household plumbing, because if you have a leak just turn of the water. If I've done something wrong during the installation of the thru-hulls...my boat may sink. Like I had mentioned before...I'm new to owning a boat, and would appreciate some advice.
