Thru hull valve size?
464
Catalina 30 MKIII Varuna Boat Club
Hi all,
Can't get down to the boat until late next week and need to order the thru-hull ball valve for my macerator. I have a '97 MKIII. Does anyone know for sure, what size valve I need? Is it 1/2" or 3/4"?
Thanks
May 20, 2016
3,015
The 36’s have a 1” valve if I remember correctly. Should be the same across the line. On exception being earlier boats with direct discharge( no macerated) which I believe is 1.5 or 2”
464
Hi all,
Thanks
Thank you much.
Ward H
Nov 7, 2011
3,841
Hi Ralph, The macerator discharge thru hull on my 93 Mk II is 3/4”.
@rpell1@msn.com
Perhaps this might help. I found this for the Mark 1.
Circa 1980 Parts Manual
This parts manual should cover most Mark I C30s built 1974-85. The rigging and gear illustrations are helpful for any upgrades. Hopefully we will obtain similar document for the Marl II and III later models. Contributions gladly accepted!
