Thru Hull Access
Augiedoc,I'm not sure how your setup is on a 22, but I am changing out my thru hull on my 26 under the galley sink in order to put in a true seacock and replace the ball valve. The area under the sink was floored with a small hole cut where the ball valve was located. In order to access the valve and make room for the seacock, I had to use a jig saw and cut the flooring away. The flooring could not be removed because it was installed and then the cabinet was place on top of it.Ben AllenMontgomery, AL"Wahoo"O'Day 26
