Bought an 85 31' this winter and after reading through the forums I thought it would be a good idea to change out the gate valves under the sink. I started to remove the waste gate valve and spun the thru hull fitting slightly. I realized after I started the project that I probably bit off more than I could chew with the limited time I have to spend at the boat - (can only work on it during weekend and it is a 2 hour drive). My concern is now, if I leave the gate valve in place for now until I have more time to work on it will I have a problem with the thru hull fitting leaking? It seems to still have a good solid bond to the outside of the hull - but I don't want to take any chances (I'll take a day of vacation if I have to to install a new thru hull even though it will p off my better half - but I would rather spend the vacation time sailing).
