Thru hull depth sounder
Sep 1, 2013
53
catalina 30 suttons bay
Has anyone replaced a thru hull transducer in the water ? I just wonder if I'm out of my mind :)
Sep 1, 2013
53
5.3 draft, and prob 10 ft of water, funny I think I know where your going with that question :)
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
Can you clarify if you are replacing only the transducer insert, or the entire through hull body? If the through hull, I'd wait for a winter project. If only the transducer, most of the modern ones (25 years) had built in automatic seals that cut off the water after a cup or so fountains in. Even without a cutoff, you can do a switch if you're quick and have the replacement handy. The fountain is scary, but doesn't have much water pressure. You also probably have a dummy transducer to put in its place. You'll need the exact model, of course , to fit hour through hull. If you want to be doubly safe, try swimming to the outside, finding the fitting by touch, and covering it with the head of a plumbers helper (plunger), with some air trapped in it. Amazing how well those things adhere to a boat.
Nov 7, 2012
678
1978 Catalina 30 Wilbur-by-the-Sea
I removed my old style thru hull transducer when on the hard. If yours is the same type (looks like a arrow and about 1/2" tall on the exterior of the hull) I would wait for a haul. The old one had to be unscrewed (pretty long metal shaft) and exited outward with about a 5/8ID hole. My new tranducer shoots thru the glass (no hole).
