Jack Beale
Recently, I've experienced what appars to be a blockage of the thru-hulls associated witht the reverse-cycle air conditioner and the refirgerator.I've been in a new marina in FL for about three weeks and I've noiced a huge bloom of very fine seaweed around the pilings. I cleaned the filter baskets on all intakes to remove debris that mostly clogged them. After replacing the filters, no water was being pumped through the systems.On closer inspection, I can get water through the systems using a hose to 'push' water through in both directions. The only 'logical' thing I can figure is that the H-380 has a screen on the seawater intakes that is blocked by the seaweed. The seaweed must be 'sucked' against the screen blocking it.Question is: Does the h-380 have a screen on the reverse-cycle air conditioner and the refrigerator raw wate intakes.Thanks
