Rich
I sail on a 1985 H31. The plug and fitting for the tube leading to the holding tank need replacement. One problem is attaching hose clamp...access to fitting from below weather deck is difficult. You can't see the fitting, much less get a hose clamp screwed on from below. Hose clamp is too big to attach above deck then drop attached fitting to deck..hole in deck's too small.Anybody out there know what I'm talking about and have a hint as to how toproceed?Opinions welcome.-Rich
