Thru Deck Fitting for Solar Panel Cable
Duke
Sep 27, 2008
58
Morgan 321 Gilbertsville, KY
I am looking for recommendations for a thru deck fitting to accommodate a flat 10 gauge duplex cable. Your suggestions will be appreciated.
Duke
Feb 6, 1998
11,723
Duke
Use round wire and a Scanstrut deck gland. There are no good water-tight glands made for flat cable that I've found other than a mess of sealant. If you can come through a vertical surface then a clam shell can be used.
Tim R.
May 27, 2004
3,626
+1 on this.
Duke
Sep 27, 2008
58
I already have flat cable and I cannot justify changing the cable to accommodate the deck fitting.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
MaineSail, Is there a plug and socket connector that you'd recommend for this application, as when you have a flexible panel on a bimini, and you'd like ot be able to remove the bimini framework, canvas, panel, and all?
Tim R.
May 27, 2004
3,626
I will tell you that I would not trust a socket/plug connector for this. I simply disconnect the wires from in the junction box under the panel.
Not sure how this is handled on the flexible panels.
Feb 6, 1998
11,723
Is there a bulkhead version of an MC-4?
Never seen one but they may be out there. I generally run a two post t-strip just below the deck gland and the solar wire can then be removed entirely.....
Jun 6, 2006
6,990
try digikey.com They have every connector known to man. Recommend ordering the catalog as it is easier to navigate and find exactly what you want.
