My life rail stanchions are bolted thru the Fiberglas (FRP) deck. I noticed "Docking Helpers" grab the stanchions to push/pull the boat. I then found some long mysterious rain leaks to be through the stanchions deck bolting. I am needing to seal the thru bolt hole. Being a Chemical Engineer I went to 3M sealants for marine applications by this link.
http://solutions.3m.com/wps/portal/...ts/~/Adhesive-Sealants?N=5510818&rt=c3&Nao=15
http://solutions.3m.com/wps/portal/3M/en_US/Adhesives/Tapes/Products/~/Adhesive-Sealants?N=5510818&rt=c3&Nao=15
The application should be more like a "O-ring" and not so much adhesive ( for all you 3M 5200 believers I would like to be able to replace/repair the stanchions in the future:naughty:
They have several types of non-silicone (silicone is short lived, no freeze/thaw properties) sealants.
Does anyone have marine experience with their product numbers....?
755 or 760 a Hyrbrid which is flexible
555 or 560 a flexible non hardening Polyurethane
Or any non-silicone sealant you have found good in a "Stressed" application.
Thanks...
Jim...
PS: Try 3M 4200 for same sealing as 5200 but can be broken with a wrench versus a chisel
Thanks...
Jim...
