Through Hulls or Seacocks?
On my 1981 Cat 30, the through hulls are fine, but lets be clear here, my seacocks were corroded & needed replacing. When I pulled the boat out for bottom painting I replaced them. Seacocks are simply the valves that attach to your through hulls (actually go through the hull). Once dry docked, remove the old seacocks (replace them) & check the through hulls for corrosion, if they look OK, I'd leave em. Be careful not to break the bond on the through hulls when removing the seacocks or you'll end up having to reseal/replace them anyhow.Bronze or teflon? Bronze unless you have a bad corrosion problem in your area/marina.
