Through Hulls open or closed?
3,319
Everytime I leave my boat for a while I shut all of the through hulls. I was told to do this but is it really necessary? I usually away from my boat a week or two. Just wondering what everyone's thoughts were on this.
Ross
Jun 15, 2004
14,693
I leave mine open BUT the boat
is in fresh water and every spring the thru-hulls get a good swift kick. If they should break off they will get replaced. They also get inspected every time the boat is boarded.
Paul F
Jun 3, 2004
827
Hunter 1980 - 33 Bradenton
problem is
The problem is you won't be there when it goes down.
Mar 22, 2004
733
Hunter 30 Vero Beach
Thru Hulls
When I got my boat, all the ball valves on the thru hulls were froze up. I think that I open and close mine to make sure that they will work when needed. If I was leaving my boat for a day I would close them. Fresh water or salt, I wouldn't want my boat on the bottom for something as easy as closing a valve. Now if you have a really crappy boat, it's well insured and want a new one, then it might be a different story.
N
nick maggio
Use Them
As already mentioned its a good idea to close them when ever gone from the boat,its easy to keep your boat from sinking plus its also a good idea to use them on a regular basis this way you know they work ok when you need them,I do forget sometimes but not often.
Catalina 320 Dana Point
I do the same thing Bad, it's good for the valves,
I sleep better, it's a win-win. I've forgotten sometimes and the boat is still afloat.
Dec 2, 1997
8,966
- - LIttle Rock
Boats also sink in fresh water.
According to BOAT/US insurance stats, for every boat that sinks underway, 4 boats sink in their slips. Read http://www.boatus.com/seaworthy/sinking/default.asp
Ross
Jun 15, 2004
14,693
Boats sink because of
indifferent maintenance. My boat sank in its slip before I owned it. I don't believe that a carefully kept boat sinks in her slip any more than a carefully maintained body fails without warning. Only when the warnings are ignored do things go catastrophically bad.
Jun 2, 2004
1,077
Several Catalinas C25/C320 USA
Thru Hulls
When I'm at the boat, they are open, when I'm not there, closed.
Jan 13, 2006
134
- - Chesapeke
Ignorance is bliss
Being a newbee, when we got our new/old boat the previous owner acted like the frozen thru hulls where no big deal so I wasn't too worried. This winter I felt they should be replaced and Googamooga, the hose to the sink valve fell off in my hand. I've no idea why it didn't sink. New valves, shut off, every time. God takes care of babies and drunks, but I'm not going to push it. Shut 'em.
Dec 3, 2003
544
None None Rochester, NY
What fails?
Is it the thru-hull that fails, or is it the hose attached to the thru-hull, or something else? Hoses and clamps should be inspected on a regular basis as well as making sure the valve works properly. What is causing these boats to sink at the dock? Most of my thru-hull valves are fairly easy to access. The one for the engine water intake is tough. You must remove a large cushion from the aft berth, remove a wooden hatch cover, lay down, and turn the lever. Come on, how many boat owners really do that every time they leave their boat? By reading the previous posts, it would seem that the majority do. My guess is that those that don't close them every time don't want to answer because they feel embarrassed or put-down.
jlp
Jul 27, 2005
30
Catalina 30mkIII Portland
Close em'
A rough count indicates my 3 thru hulls lead to at least 12 hose clamps, fittings, tees tanks etc. most of which are near or below the water line. Not embarrased to say I close em' jeff
May 23, 2004
3,319
Hey Jorge
I have my Catalina 30 at the new marina on Winkee Doodle Point (Curley's Packing Co.). The boat is named the Spirit of Liberty. Hope to see you out there!
Benny
My rule is;
If the boat is unattended, close them. I know sailors that will not close them and they are the type of persons that if the boat sinks they would blame bad luck or everyone but themselves. If it happened to me I would be kicking myself for laziness and stupidity so in order to avoid that I close them.
rfrye1
Jun 15, 2004
589
Hunter H376 San Diego
Close 'em
If theres a failure, its bad news. Also by opening/closing valves they're less apt to freeze up. You should lube them occasionally too.
Apr 12, 2005
263
Hunter 36 Cobb Island
Hey Bad Obsession
I went drove by your Marina Sunday P.M. What's the depth getting there and at the dock? The chart say's 3 feet. Any facilities? Price? I couldn't make out the sign in the rain. Not many Sail boats at CBYC to mingle with. Sure are plenty there though!!My email is titantriggerfish@adelphia.net.
Tom S
Ok, I'll admit it .... I'll be honest
I don't often close them. I know, I know,.... I should, but I'm at my boat every week. If I was away for a while I'd probably close them. But one thing I am NOT ignorant of is my boat. I know it very well. I check and look at my plumbing often, if there was something about a thru hull or valve or underwater hose or SS clamp that bothered me, then I would probably close it until I fixed what was bothering me. Yeah I know things can happen (and they do) so I am not advocating this for everyone. There are many designs and materials used on boats that would concern me more and make me close them(Cheap hose, old electrolysis ridden sea-cocks, etc) I was on a new motorboat yesterday that had the cockpit scuppers drain to an underwater thru-hull on the back of the boat that didn't even HAVE a way to close it. And the hose that was attached did not look like that really really heavy black exhaust hose, it was that hose that look like it goes on a vacuum cleaner. It looked open to any sort of loose object puncturing it and the boat would probably sink in 10 minutes. Not to mention that the bilgepump was so small I don't think it could drain a bath-tub (It was a "Sea Boss 255" walkaround)
Paul I aboard One Slip
More Honesty
I don't close them either. Mine are not in convienient places (Hunter 31). I do check their condition on a regular basis however.
