A
Ameribritalia
For lack of the correct jargon, I have a through-hull rudder, (doesn't hang off the back with pindles & gugeons). It bangs slightly back and forth inside the fiberglass tube that most likely over the years has worn out, can anyone recommend what I could use to add to the inside making up for the space. I heard someone else with the same problem used some sort of nylon or teflon sheath placed over the tubing attached to the rudder that slips well inside the through-hull tube, any ideas appreciated.
