I just wanted to share an experience which may be helpful to someone in the future, as this site has been so helpful to me in the past.
Recently, I went for a five hour day sail in Charleston Harbor in our '86 O'day 31, out the jetties and into the Atlantic for a while. As many of you do, I run through a checklist to be sure everything is in working order and ship-shape, including assuring the impeller is pumping the engine cooling salt water out the stern - which it was.
After a great sail with nice 1-3 foot following seas pushing me back into the harbor, I pull into my slip, tied up, and went below to find my floorboards floating in 5-7 inches of water. The bilge pump is on, but not making a difference as far as I can tell. A quick examination of all the sea cocks finds no source of the water. But the water isn't rising, so I grabbed a square bucket (because it can bail much water flush along the floor) and start bailing.
I could stop right here and tell you the problem, but I'll drag the story a little longer and say that I still had my stereo on and didn't determine what was wrong until I turned it off and heard water running behind the engine.
Sometime, between checking the stern for the exhaust water and returning, the the plastic through-hull for the bilge pump waste snapped off at the stern and the hose fell into the space behind the rudder. There is a hole in the stern next to the engine exhaust which wasn't there when I pulled out. The bilge pump was recycling the water in the boat! I've no idea what caused the piece to fail. What's more alarming is the piece, which I generally consider to be above the waterline, is actually well below the water line while underway, especially with a following sea. So I was by myself, never going below for 5 hours, and slowly draining the ocean into my boat while the bilge pump merrily recycled the water in the boat! The piece lasted 30 years, but it's now a brass fitting.
All is well and I hope someone finds the story useful. I like to say that you can do something you enjoy for years, and then once in a while, you get 15 minutes of real experience.....
