S,
I have the original transducer on my 1980 C30 for the old time Datamarine depth gauge. I've not used this since my first Loran & two GPS's later. I installed my first epoxy'd/caulked in-hull trans. and recently with my new Garmin, have a newer in-hull one.
The old ones are still in place but do not interfere. All in the area just STBD of the fuel tank. It was an easy job, what with making a collar from a plastic milk jug. Used some latex caulk to hold this in place. Mixed the epoxy caulk made for the trans., poured it in carefully set the transducer being careful no air bubbles and Viola, beautiful bottom reads.
To find a spot, I took a plastic baggie filled with water. Put the sender in the bag up against the inside hull moving it around to ensure a good reading on your instrument. If your bottom finder is located elsewhere, have a friend call out the good spot or vice-versa.
I never have to worry about bottom paint or barnacles etc.
Just a suggestion pal.......
CR
