Cable Clam
I used a 14 gage, 5 conductor cable for the mast(West Marine #242040). Two grounds and three hot. The three hot conductors go to: the masthead light, the anchor light and the spreader lights respectively. The grounds are: one for the masthead and anchor lights combined and the other for the spreader lights which run a lot more current. The through deck fitting is a "Cable Clam" (West Marine #540732 but they come in 3 sizes). You have to drill the rubber gasket out to fit your wires. Use a new, sharp, brad-point bit, a cordless drill and lubricate with soapy water (don't electrocute yourself using a regular drill motor and water). Don't forget to put the parts on in the right order, base first pointing down then the rubber gasket with the smaller end of the taper down then the cover. Use soapy water to lubricate the cable while pushing it through the gasket. Bed the plastic base to the deck with 4200. Mine has been in for two years and hasn't leaked a drop yet. P.S. Don't forget to use a grommet where the cable passes through the hole into the mast. It keeps the rain and bugs out and prevents chafe.
