I am with Fred -
Just hope that Fred is ok with that. I probably should have asked. Oh my! Now where did I put my Strunk and whatever?Had a cable break once. I was at the entrance to the Ballard Locks. It was the shift cable for the gearbox. Good luck was with me at the time. But then again, bad luck started it all. Must not discriminate... Plus that is just my opinion...I was in neutral and going very slowly (under two knots) just like the documented rule said on the sign. I steered against the wall at the entrance and lassoed a cleat. The wind helped a lot.That is why I would not ever use any clamp which stresses the cable in any way. If it had been the throttle, I might not have been able to slow down or avoid hitting someone or something else. The pedestal screw will work but I have added another one by drilling and tapping at another place on the shaft. I think I used a stainsless steel setscrew which had the business end ground flat. I used a second set screw atop the first to keep it in from working loose.I hope no one is offended by my: spelliing, gramm er, use of words like: with, lassoed, screw, good, bad, opinion, shaft, neutral, business, etc. My apologies in advance or is that too soon?
