		Mickey Goodman
I have a 88 Hunter Legend 37 and am experience throttle vibration which will move the throttle to a slower setting which will reduce speed.  Since I have an Edson pedestal in the boat I called them and thier solution was to put a wire clamp on the throttle cable close to the connection to the throttle lever on the engine.  Thier feeling was that if you put some pressure on the cable it would put resistance which would stop the wondering of the throttle.I did that and it reduced the wondering significantly but not completely.  This procedure caused another problem.  By putting pressure on the cable it seemed to slightly shorten the cable and cause the idle to move from about 800 rpms to about 1,000 rpms.I have just recently replace the throttle and shift cables and have adjusted the throttle cable as far as I dare without having the end fittings fall off.  I know I have the correct cable length so that wouldn't be the problem.The route of this new problem is the cable clamp.Is there another way of reducing the throttle vibration/wondering without the cable clamp?  Is there another way of adjusting the cable for the idle adjustment?
