Length
The length does not have to be that precise so If you just get a flexible tape you can come close. Trick is to make sure that when you remove the old cable you attach a line to it so you can pull the new cable through. If you have access to a West Marine or what ever, you can remove the old cable and take it in for a perfect match. Good luck!
