Throttle cable replacement
grigs
Jan 2, 2007
37
Catalina 25 East Greenwich
HELP"""""""
Maybe try the Ask All Sailors Forum , There are some sharp guys over there that probably just didn,t pick up on the ????? Maybe they don,t read the Catalina only site. Grigs
Mar 31, 2004
244
Catalina 380 T Holland
The short answer to your question is no.
However, to get the long answer, go to the C-320 association web site and sign up for the list serve. Most of theh technical discussion on the C-320s takes place on that list. That exact question has been asked and answered in detail. Steve Alchemist C-320 #909
G
Glenn
Is it the cable?
If you have an Edson pedistal with the throttle, it could be the bushing at the lever. My trans and throttle were very stiff and was told by the shipyard to disconnect the cable from the lever to determine if the cable was the problem or the bushing. When disconnected, if the cable is still stiff, that's the problem, if not then the lever will still be stiff and it would be the bushing. Try this unless you already know.
