Throttle Cable needs lubrication
As of my last outing the throttle is not allowing me to slow RPM's to much under 2000. Normally I can slow to about 1200. I'm guessing either the cable or the throttle needs lubrication. I haven't figured out how to break into the Edson Shift/throttle mount at the helm. Is there an easy way to get in there? Do I have to take the whole cable out to lubricate it? What is best to use? What about the throttle itself?
Oh yeah. Its a Yanmar 3GMf engine.
NYSail
Jan 6, 2006
3,137
Beneteau 423 Mt. Sinai, NY
sounds as if your cable is slipping. Before opening the pedistole, I would check where it attaches to the engine. Also I am pretty sure the last cable I replaced indicated not to lubricate.
capta
Jun 4, 2009
4,909
Morse, (I assume it's a Morse cable?) makes a cable lube attachment. I remember them being pretty expensive so I always borrowed one from a boat yard. Pretty easy job.
My compass had to be removed to reach the shifter. Also easy.
Jimm
Hunter 33.5 Bodkin Creek - Bodkin YC
My cable got lubricated by mistake while making related repair -- now it doesn't want to hold position ............ don't think lubricating is desireable or your answer.
Correction: I think the single lever throttle was made by Whitlock. I haven't found anything useful on the Lewmar web site (Lemar bought Whitlock).
There must have been some slippage somewhere because one day the idle is 1200 and the next its 2000.
Yesterday I was looking at the situation and it appears to me that the throttle when pushed forward actually pulls the engine control arm back (aft). Can anyone confirm that? Furthermore, the control arm (On the engine) doesn't seem to go forward enough (With the shift lever in neutral) to contact the idle adjustment screw by about 2mm. How do I adjust that?
Oct 15, 2008
23
Banjer 37 San Rafael
My throttle/shifter single lever combination is a Morse from 1972, sorry, no model number. My symptoms were engage the tranny at 1000, not while idling at 600, 1000 rpm engaged, or 1500. Being new to diesel boats it didn't seem odd to me, and two professional mariners didn't mention it either, but idling at 1000 equals 5k speed. Some low speed control problem. I tried all manner of dockside fixes to resolve the problem, My engine was either idle neutral, 1000 and 5K or 1500 at 6.5k. No professional engine person I talked to had any idea, none admitted any knowledge of the Morse single lever control.
I finally bought a new Morse cable, I tried to fit the ends exactly the way the old cable was, the problem was worse, engage the tranny at 1200. I went online to find some information about the cable adjustments, but got only vague hints, but I came up with an understanding of how that system works. It seemed the cable adjustment was too tight, even on the old cable, with the cable adjusted properly, it no goes into get while the engine is at idle, I can then raise the rpm to 1000, but anything between 600 and 1000 returns to 600 when I let the lever go. I decided this is a brilliant bit of the throttle lever design, allowing for a quick low speed thrust with idle return for low speed maneuvering.
The new cable moves a slight bit easier than the old cable, my problem was completely in the mis-adjusted linkages on both the transmission and throttle.
Based on my experience, I am betting your problem is a loose connection on one end of either cable.
