I am looking for some help on my transmission and throttle cables. Attached to a Merriman pedestal, my gear shift lever moves smoothly between neutral and reverse. Moving the lever to forward from neutral requires a very hard push to the extent the lever rests against the pedestal. FWD won't engage unless the lever is in that position. It takes two hands to pull the lever back to neutral.
I don't know where to begin trouble shooting and don't want to dismantle the pedestal if I don't have to.
Could the cable be too long? There is about 2-2 1/2 feet looped in the tray/cover in the aft berth.
Also after setting my throttle it fades back toward idle if I don't attach a small bungee
