Would not use Hunter for Prop Specs.
Sid:I think you (anyone) would be much better off using a PROP EXPERT for determining which prop to use. The prop that came with some of the boats was not necessarily the correct one to begin with. Hunter is going to look at their documentation and give you the specs as the boat was delivered. The Prop people have programs that will calculate which prop you should have for your boat, engine, and transmission combination. If there is something wrong with the prop that THEY sell you, you will have someone to go back to and complain.
