Three-fold purchase
Roger,For purposes of illustration, let's consider the upper block the one with the becket. The becket is the eye on the bottom of the block. It is necessary to lay one of the three sheaved blocks on it's side with the other laying 90 degrees opposed, or on it's sheaves. The difficulty in reaving this tackle is that, if you do not get it right, the top block will capsize itself and you'll not get a straight pull. Attach the bitter end to the becket. Reeve the line through the center sheave of your lower, or floating, block. Then back up to the stationary block to one of the outside sheaves and come back down to an outside sheave. You will then go up and through the other outside sheave, through the remaining sheave on the floating block, and finally through the center sheave of your stationary block. The two blocks will end up 90 degrees opposed to each other as they hang.This is a rare purchase for line, but not uncommon in wire rope. With line you end up with the full 10% friction loss per block. So, on a six-to-one purchase you will lose 60% of your mechanical advantage to friction. Wire rope and the blocks used for the same is not as inefficient in this purchase.
