Is this even possible? I twisted-off about 1/2 of the threaded brass post on an AGM battery when installing it yesterday. I foolishly didn't use a torque wrench! Thank goodness there was enough post left to install a single terminal lug with no flat or lock washer, and there are still a couple of exposed female threads at the top of the nut, i.e., the remaining post doesn't extend past the end of the nut; but, at least I can still use the battery.
Is there a method to repair of otherwise restore full post height to this battery?
(I didn't look very closely at the battery when this happened. It occurs to me now that it could be a brass stud turned into a tapped hole in the ground plate of the battery. Does that even make sense?)
Thanks,
jv
Thanks,
jv
