This One Saved the Cruise, (maybe even the marriage)
Sep 22, 2009
134
Hunter 36 Seattle, WA
Hunter Association of Puget Sound (HAPS to you, www.hunterpugetsound.com) is sponsoring a thread of stories on what engine spares saved your cruise. The hope is that it will enable us to decide/inspire us to know how crucial it might be to carry a specific engine part aboard.
Stories from any Hunter owner are welcome
Jul 7, 2004
8,525
Hunter 30T Cheney, KS
A starter. They are easy to change if you have the wrenches.
I had a starter break on me while I was single handing. It was the strangest thing. I was getting ready to motor in to my slip. I tried to start the diesel but it wouldn't kick over. I actually thought it was the batteries. I called in for a tow and waited. Then I tried it once more and it fired up. I cancelled the tow and motored in. Long story short: After a bit of troubleshooting in the slip, I decided to pull the starter. When it came out in pieces I was pretty sure I found the problem. My guardian angel held the starter together for one last time and got me home safely.
Likes: stuartsw
Sep 22, 2009
134
This one didn't save the cruise:
When we bought a brand-new Hunter 36 in 2009, I thought I was being particularly prescient in asking the mechanic who did our 50-hour engine service to spec and order whatever spare parts he thought we needed. Seven years later, my water pump belt broke while we were in a sea lane, with an approching ferry. I spread sail and went below where I struggled to replace the belt, while the Admiral expertly avoided the ferry and sailed us to a temporary dock about 45 min away.
Once we got to the dock, a friend confirmed my suspicion: the mechanic had supplied the wrong-sized belt. I now carry the correct size aboard, for both of my engine belts. And I have a little less trust of parts suppliers. (Other than sailboatownersdotcom, of course. They actually hesitate before they tell you that they know something.):clap:
Rick D
Jun 14, 2008
7,201
When I race with knowledgeable crew, they are always surprised that I carry about 50 pounds (at least) of tools and spares in my "garage" under the V-birth (but only 40 feet of anchor chain). Over the years, I have had to change an impeller, rig a patch on a cooling water pipe, replace an oil filter that had a pin hole in it (!), replace a belt, snug up a loose solenoid bolt, bypass a fried battery combiner, replace a missing alternator bolt, clean out a blocked raw water exhaust manifold injection, and probably a bunch of stuff I forgot. Those were all things done underway. I don't go anywhere without my tools and spares! And, that doesn't include the usual head repairs, fresh water pump, etc.
Likes: Ken13559
Oct 1, 2007
1,865
Some years back we had arrived at our destination for the day Gloucester MA. As we maneuvered to pick up our mooring the engine alarm bell sounded. I looked at the instruments and the engine oil pressure read zero (0). Not good. I immediately shut her down as my wife picked up the mooring. I knew what I would find below. 5 quarts of oil in the engine bilge and main bilge. Ugh! What a mess. Know what it was? The oil pressure sender had failed and squirted out 5 quarts of oil. Probably had been going on for hours as we had powered most of the 50 miles from the Cape Cod Canal. So now I carry a complete refill of oil, plus an additional quart for top offs, and an oil pressure sender.
Oct 30, 2011
542
klidescope 30t norfolk
I looked at the instruments and the engine oil pressure read zero (0). Not good. I immediately shut her down as my wife picked up the mooring. I knew what I would find below. 5 quarts of oil in the engine bilge and main bilge. Ugh! What a mess. Know what it was? The oil pressure sender had failed and squirted out 5 quarts of oil. Probably had been going on for hours [/QUOTE]
I had that happen must be pretty reg. Plastic core just blows out. I just drove a hard wood bung in hole put the 2 quarts I had on board and a quart of diesel.
