Use proper thinner
Mitch, Use the recommended thinner indicated on your bottom paint. That way you can't go wrong. Thin the paint according to their recommendation - usually 10% or so and it will be easier to apply especially when you get to the end of the paint when you're tired and the roller or brush is clogged! The thinner will evaporate shortly after application causing no harm to the bottom paint. I've been rolling my bottom for 14 years - I apply one coat of quality ablative paint each year and I rarely get any flaking and little or no buildup.
